VCDS Beta 26.4 - VW Golf 8 MJ2024
Tuesday,21,April,2026,09:40:06:59090
VCDS -- Windows Based ■■■/VAS Emulator Running on Windows 11 x64
VCDS Version: 26.4.0.5 (x64)  HEX-NET2 CB: 0.4713.5
Data version: 20260410 DS376.0
www.Ross-Tech.com
VIN: WVWZZZCD0RW033350   License Plate:
Mileage: 9639km-5989mi   Repair Order: Golf 8 CG
Chassis Type: CD-VW38 (5WA)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 42 44 52 5F 61 6C 75
          A5 C4 CC D6 D7 8107
VIN: WVWZZZCD0RW033350   Mileage: 9639km-5989miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
23-Brake Booster -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: OK 0000
75-Telematics -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
C4-DC/DC Converter -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
8107-Antenna -- Status: OK 0000
Address 01: Engine (2D2D2-DLAA)       Labels: None
   Part No SW: 05C 906 032 AK    HW: 05C 907 394 B
   Component: R3 1.0l TFS   H01 2369
   Revision: 42201001
   Coding: 0125001223640D0830086000000000000000000000000000
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_ECM10TFS03005C906032AK 002003
   ROD: EV_ECM10TFS030_VW38.rod
   VCID: 6882D33DE2FDB66A7B6-803C SFD [x]
   VINID: 9E69EAAAA4D40229C00C30C5009E04D6A8
1 Fault Found:
26219 - Implausible Data Received from ABS Control Module
          U0415 00 [00100000] - -
          [Invalid Data Received FromAnti-Lock Brake System Control Module]
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Mileage: 9485 km
                    Date: 2026.03.05
                    Time: 08:52:37
                    Engine speed: 920.00 /min
                    Normed load value: 17.6 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 92  C
                    Intake air temperature: 45  C
                    Ambient air pressure: 970 mbar
                    Voltage terminal 30: 14.929 V
                    Unlearning counter according OBD: 27
                    Ignition timing adjustment cylinder 1: 16.0 Degrees
                    O2 sens. 1 bank 1 upstrm oxi cat: raw value: 0.995 counts
                    Primary injection: quantity setpoint: 5.52 mg/stroke
                    Fuel high pressure sensor: actual value: 190.3 bar
                    O2 sen. bank 1 dwnstrm oxi cat: elec. corrected Urie sen. value: 0.663 V
                    IN_Injection_speed: 920.25 /min
                    Camshaft adjustment: exhaust: bank 1: actual value: -0.8
                    Camshaft adjustment intake bank 1: actual value: 0.0
                    Throttle valve position (absolute): 11.8 %
                    Setpoint generation interior torque: 16.0 Nm
                    Battery voltage: 14.929 V
                    Accelerator pedal travel: raw value: 0.00 %
                    Control Module temperature: 43.2  C
                    Engine oil temperature: 77.4  C
Readiness: N/A
Address 02: Auto Trans (J743)       Labels: 0CW-927-769.clb
   Part No SW: 0CW 906 556 K    HW: 0CW 300 051 E
   Component: GSG DQ200G2.1 H07 0363
   Revision: 00007009    Serial number: CU502312165736  CVN: FBE2314A
   Coding: 0014
   ASAM Dataset: EV_TCMDQ200022 001001
   ROD: EV_TCMDQ200022.rod
   VCID: 54FA17CD4E75228A27E-8000
   Subsystem 1 - Part No SW: 5WA 713 033 CC    HW: 610 5
   Component: ZSB_SB_AUTO    H08 1034
   Serial number: 20231130000090237912
   Subsystem 2 - Part No SW: 5H0 713 059 Q    HW: 5H0 713 059 Q
   Component: ZSB_SB_Mono    H03 0014
   Serial number: 92478WJD00689
No fault code found.
Address 03: ABS Brakes (J104)       Labels: 5WA-614-517-V1.clb
   Part No SW: 5WA 614 517 BM    HW: 5WA 614 517 P
   Component: ESC           H14 0133
   Serial number: 63303000001746  Dataset Number: V03935387TE 0001 CVN: B5E07323
   Coding: 24FC24902223446F527A50050AC36186ADB558F54AC86708A1BCA231018FF141822814
   ASAM Dataset: EV_Brake1ESCEPBMQB37W 013056
   ROD: EV_Brake1ESCEPBMQB37W_013_VW38.rod
   VCID: 147AD7CD8EF5E28A67E-8040 SFD [x]
1 Fault Found:
8472 - Implausible Data Received from Airbag Control Module
          U0452 00 [00100000] - -
          [CCan_AB_Gurtschloss_FA_ext_inv]
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 P    HW: 5WA 959 436 P
   Component: Kessy IOBOX   100 0725
   Serial number: --------------- Dataset Number: V03935341VY 0001
   ASAM Dataset: EV_Kessy37w 004024
   ROD: EV_Kessy37w_004.rod
   VCID: 6194CE1901C7C722BC8-8034
Address 08: Auto HVAC (J979)       Labels:* Redir Fail!
   Part No SW: 5WA 907 007 AC    HW: 5WA 907 007 AC
   Component: AC Automat    H31 3623
   Serial number: --------------- Dataset Number: V03935418JG 0001
   Coding: 002000019011120010100010111011110000131100200000000000000000
   ASAM Dataset: EV_ACClimaPREVW38X 001102
   ROD: EV_ACClimaPREVW38X_VW38.rod
   VCID: 0842F3BDC2BD566A9B6-805C
   Air quality sensor:
   Subsystem 1 - Part No SW: 5Q0 907 659 D    HW: 5Q0 907 659 D
   Component: G238 _AQS      H02 0003
   Serial number: 00000000000002858484
   Rear air conditioning block 1:
   Subsystem 2 - Part No SW: 11A 907 049     HW: 11A 907 049
   Component: E265 KPH       H02 0183
   Serial number: G07S05.12.2300970824
   Interior temperature sensor:
   Subsystem 3 - Part No SW: 5WA 907 527 A    HW: 5WA 907 527 A
   Component: E857           H01 0103
   Serial number: 00002031223220257520
2 Faults Found:
1048834 - Functional Limitation due to Energy Management
          B10CD 00 [00001000] - -
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 26
                    Mileage: 9485 km
                    Date: 2026.01.20
                    Time: 15:32:57
                    Voltage terminal 30: 15.1 V
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 1
                    Auxiliary heater: in stages-Actual value: 0
                    Auxiliary heater: in stages-Specified value: 3
                    Auxiliary heater: in stages-Specified value for control: 3
                    Auxiliary heater: controlled-Status: not active
                    Auxiliary heater: controlled-Current: actual value: 0 A
                    Auxiliary heater: controlled-Power: actual value: 0 W
                    Auxiliary heater: controlled-Power: target value: 0 W
1048838 - Functional Limitation due to Energy Management
          [Function limitation due to energy management 03]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 8
                    Reset counter: 29
                    Mileage: 9484 km
                    Date: 2025.12.25
                    Time: 07:32:17
                    Voltage terminal 30: 11.8 V
                    CAN input signal(s) status-Transport mode: OFF
                    CAN input signal(s) status-Static current measuring mode: OFF
                    CAN input signal(s) status-Front windshield wiper: OFF
                    CAN input signal(s) status-Energy management: shut-off stage: Deactivation stage 1
                    CAN input signal(s) status-Wipe wash: OFF
                    CAN input signal(s) status-Rear window heater actual value: OFF
                    CAN input signal(s) status-Back-up lamps: OFF
                    CAN input signal(s) status-Actual value of windshield heater: OFF
                    Blower reduction: No switch-off: no reduction
Address 09: Cent. Elect. (J519)       Labels: 5WA-937-08X-V1.clb
   Part No SW: 5WA 937 086 BR    HW: 5WA 937 086 AT
   Component: BCM37w_M134 0183
   Serial number: BXJ53F141223940 Dataset Number: V03935400FM 0001
   ASAM Dataset: EV_BCM37w 007001
   ROD: EV_BCM37w_007_VW38.rod
   VCID: 2216811544419C3AE52-8076 SFD [x]
   Wiper motor control module:
   Subsystem 1 - Part No SW: 5H1 955 119 B    HW: 5H1 955 119
   Component: FWISCHER_MYJT  003 0061
   Serial number: 907453F0302332000450
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS           054 0206
   Serial number: S4Y23M12D13H16M14S58
   Light switch:
   Subsystem 3 - Part No SW: 5H0 941 193 AK    HW: 5H0 941 193 AK
   Component: LiSi           H06 0008
   Serial number: 92471WKS001XA
   Control head for driving and comfort functions:
   Subsystem 4 - Part No SW: 5H0 925 200 T    HW: 5H0 925 200 T
   Component: DiETa          H07 0008
   Serial number: 92471WLC000FQ
   Roof electronics control module:
   Subsystem 5 - Part No SW: 5H0 959 561 BM    HW: 5H0 959 561 BM
   Component: -VW----LINDA-  504 0831
   Serial number: MW3LND15122300011883
   Steering Column Switch:
   Subsystem 6 - Part No SW: 5Q1 953 507 GA    HW: 5Q1 953 549 F
   Component: J527 SMLS MQB  005 0080
   Serial number: 00000006122308491883
2 Faults Found:
15400960 - Secure Onboard Communication
          U14FD 00 [00101100] - Time Server not Available
          [Sichere on-board Kommunikation: Zeitserver nicht verf gbar]
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 126
                    Reset counter: 40
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    Engine run: OFF
                    Status of brake lamp switch: discrete: OFF
                    Brake lamp switch via CAN: status: OFF
                    Voltage: 11.7 V
                    Outside temperature: 12.0  C
                    Light switch position: automatic
219136 - Remote key 1
          B1479 18 [01101000] - Current Too Low
          [Funkschl ssel 1 --> Batterie leer]
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 29
                    Mileage: 9486 km
                    Date: 2026.04.01
                    Time: 15:38:26
                    Terminal 15 status: On
                    Terminal 50 status: On
                    Engine run: OFF
                    Status of brake lamp switch: discrete: On
                    Brake lamp switch via CAN: status: On
                    Voltage: 11.6 V
                    Outside temperature: 14.0  C
Address 10: Park/Steer Assist (J446)       Labels:* None
   Part No SW: 5R3 919 294     HW: 5R3 919 294
   Component: PDC 08 Kanal  H05 1550
   Serial number: 000995460324008 Dataset Number: V03935375FW 0001
   Coding: 0040010011
   ASAM Dataset: EV_EPHVA18VW3800000 002036
   ROD: EV_EPHVA18VW3800000_VW38.rod
   VCID: 7CAA9F6D86650ACA8FE-8028
1 Fault Found:
10494468 - Parking Sensor; Front Right Center
          B10F9 F5 [00100000] - Ice or Dirt Detection
          [Geber f r Einparkhilfe vorne rechts mitte - Schmutz bzw. Eisbildung]
Address 13: Auto Dist. Reg (J428)       Labels:* None
   Part No SW: 5WA 907 572 C    HW: 5WA 907 572 A
   Component: ACC BOSCH MQB H45 0461
   Dataset Number: V03935392FC 0001
   Coding: 29031075007740451247400800C040C44E4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW380 004021
   ROD: EV_FRONTRADARBOSCHVW380_004_VW38.rod
   VCID: 4ECE05A56059485A11A-801A
3 Faults Found:
209054 - Databus
          U1123 00 [00101000] - Received Error Message
          [FAULT_BV_BLINDNESS_ERROR]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 3
                    Reset counter: 4
                    Mileage: 7370 km
                    Date: 2025.08.27
                    Time: 06:07:45
2425 - Databus
          U1122 00 [00101000] - Implausible Message
          [FAULT_SENSORFUSION_INPUT_CAMERA_NOT_AVAILABLE]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 4
                    Mileage: 7370 km
                    Date: 2025.08.27
                    Time: 06:07:45
0578 - Databus
          [FAULT_APS_BLINDNESS_DETECTED]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 25
                    Mileage: 9475 km
                    Date: 2025.12.08
                    Time: 11:32:27
Address 15: Airbags (J234)       Labels:* 5WA-959-655.clb
   Part No SW: 5WA 959 655 L    HW: 5WA 959 655 L
   Component: AirbagVW40    010 0636
   Serial number: 000000003C0J2RA Dataset Number: V03935376EV 0001
   Coding: 88CC008000F0C000000000400000000051540000205400004000F68000130065
   ASAM Dataset: EV_AirbaVW40SMEVW38X 001032
   ROD: EV_AirbaVW40SMEVW38X.rod
   VCID: 6092CB1D0ACDCE2AB36-8034 SFD [x]
   Crash sensor for side airbag: driver side rear:
   Subsystem 1 - Part No SW: -----------    HW: 480 051 212 23
   Component: SideSensor_Dr  000 0149
   Serial number: 35100009EC87D1950A9K
   Crash sensor for side airbag: passenger side rear:
   Subsystem 2 - Part No SW: -----------    HW: 480 051 212 23
   Component: SideSensor_Pr  000 0149
   Serial number: 3520000BCC74BE08248H
   Crash sensor for side airbag: driver side:
   Subsystem 3 - Part No SW: -----------    HW: 480 000 811 23
   Component: SideSensor_Df  001 0887
   Serial number: 35700000000E767DEB67
   Crash sensor for side airbag: passenger side:
   Subsystem 4 - Part No SW: -----------    HW: 480 002 411 23
   Component: SideSensor_Pf  001 0887
   Serial number: 358000000002B01C2C6J
   Crash sensor for front airbag: driver side:
   Subsystem 5 - Part No SW: -----------    HW: 480 050 801 24
   Component: FrontSensor_D  000 014A
   Serial number: 3550000B0CE3DA0B628H
1 Fault Found:
9444359 - Safety belt switch - driver side
          B101C 07 [00001000] - Mechanical Failure
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 126
                    Mileage: 9475 km
                    Date: 2025.11.28
                    Time: 08:25:53
Address 17: Instruments (J285)       Labels:| 5H0-920-KOM-V1.clb-SRI2
   Part No SW: 5H0 920 340 C    HW: 5H0 920 340 C
   Component: KOMBI         310 7380
   Dataset Number: V03935364SX 0001
   Coding: 04A4004063840008018062032000080800300800
   ASAM Dataset: EV_DashBoardVDDMQB37W 003035
   ROD: EV_DashBoardVDDMQB37W_003_VW38.rod
1 Fault Found:
16777020 - Control unit for information electronics 1
          U1054 00 [00001000] - No Communication
          [TEL_0x28 communication error bap_error_timeout heartbeat]
             Freeze Frame:
                    Fault Priority: 6
                    Reset counter: 138
                    Mileage: 5625 km
                    Date: 2025.06.02
                    Time: 12:13:01
Address 19: CAN Gateway (J533)       Labels:* None
   Part No SW: 5WA 907 530 AB    HW: 5WA 907 530 L
   Component: GW2020 High   778 7105
   Revision: --------    Serial number: 771049110023352 Dataset Number: V03935393AA 0001
   Coding: 0000810D6700000003000000012303365301600902000300030100010001010000000000000000000000000000000000
   GVL: 3D0000000208428C80008002C800204004104000004400000000000000000044
   ASAM Dataset: EV_GatewMQB2020 006012
   ROD: EV_GatewMQB2020_006_VW38.rod
   VCID: 0842F3BDC2BD566A9B6-805C SFD [x]
   Battery Monitoring Control Module:
   Subsystem 1 - Part No SW: 5WA 915 181 D    HW: 5WA 915 181 D
   Component: J367-BDMConti  H04 1070
   Serial number: 76407104002312080125
   Multi-function steering wheel control module:
   Subsystem 2 - Part No SW: 3G0 959 442 AD    HW: 3G0 959 442 AD  Labels: 3C8-959-537.CLB
   Component: E221__MFL-PR6  H07 0120
   Serial number: PR6-0440079339235068
7 Faults Found:
1049121 - Databus for Driver Assistance Systems
          U15DE 00 [00100000] - No Communications
2175079 - No Communications with Emergency Call Module
          U10E1 00 [00101000] - -
1049254 - Ethernet Databus Branch 6
          U1231 00 [00100000] - No Communication
          [Ethernet_databus_no_communication_branch_6_/_port_7]
2498675 - Ethernet Module for Information Electronics 1
          U1645 00 [00100000] - No Communication
          [Information_electronics_control_module_1_no_communication_vlan]
8397569 - Quiescent Current
          U1406 00 [00101000] - Too High
8397571 - LV Energy Management
          B1802 F1 [00100000] - Warning Triggered
8466689 - VKMS
          B18B0 F0 [00101000] - Missing Adaptation
          [VKMS_new_download_container_required_due_to_vehicle_change]
Address 23: Brake Booster (J539)       Labels: None
   Part No SW: 5WA 909 059 AB    HW: 3Q0 909 059 C
   Component: EBKV          H09 0372
   Serial number: BPA085091223013 Dataset Number: V03935367RC 0001
   Coding: 1302C104730000CE39E79C73000049922449922400
   ASAM Dataset: EV_BrakeBoostG2BoschVW37W 016028
   ROD: EV_BrakeBoostG2BoschVW37W_016_VW38.rod
   VCID: 1072DBDDBAED1EAA436-8044 SFD [x]
3 Faults Found:
107008 - No Communication with Transmission Control Module
          U0101 00 [00100000] - -
          [ComScl_Getriebe_11_Timeout]
107024 - Transmission Control Module
          U14E4 00 [00100000] - Received Malfunction Value
          [Scl_Getriebe_11_GE_Fahrstufe_Error]
1024368 - Brake Booster
          C1187 F6 [00100000] - Function Limitation due to External Brake Pressure Build-Up
          [ActiveRestrictionDetected]
Address 2B: Steer. Col. Lock (J764)       Labels:| 1EA-905-861.clb
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H10 0040
   Serial number: 23000275237011 Dataset Number: V03935336NF 0001
   Coding: 8800000000000000
   ASAM Dataset: EV_ELVMarqMQBA0 002004
   ROD: EV_ELVMarqMQBA0_VW38.rod
   VCID: 3236715514A10CBA152-8066
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 5Q0 959 593 L    HW: 5Q0 959 593 F
   Component: TSG FS004 0350
   Serial number: YE007WKU29494 Dataset Number: V03935387Z  0001
   Coding: 003B03208000040008001000
   ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001018
   ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
   VCID: 4AC609B59C31647A4D2-801E
   Left rear door control module:
   Subsystem 1 - Part No SW: 5Q0 959 408 G    HW: 5Q0 959 164 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  007 0011
   Serial number: 00000000000075856226
   Coding: 110000
Address 44: Steering Assist (J500)       Labels:| 5WA-907-14X-V1.clb
   Part No SW: 5WA 907 144 G    HW: 5WA 907 144 C
   Component: BASGEN1MQB37  102 1040
   Serial number: 02972333 Dataset Number: V03935354FZ 0001
   Coding: 0000000000000100000102010100010000000101010101
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 007046
   ROD: EV_SteerAssisBASGEN1MQB37_007.rod
   VCID: 4DCC02A96D5F7342680-8018
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q0 959 592 L    HW: 5Q0 959 592 F
   Component: TSG BFS004 0350
   Serial number: YE007WKP13331 Dataset Number: V03935386XH 0001
   Coding: 003B01208C00040000801000
   ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001018
   ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
   VCID: 49C436B999376F62448-801C
   Right rear door control module:
   Subsystem 1 - Part No SW: 5Q0 959 407 G    HW: 5Q0 959 163 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  007 0011
   Serial number: 00000000000077070237
   Coding: 090000
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 5H0 035 820 P    HW: 5H0 035 820
   Component: MU-O-ND-EU    H67 1985
   Serial number: WG8LGM050124000 Dataset Number: V03935418MQ 0001
   Coding: 23800000000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB37w 001002
   ROD: EV_MUOIMQB37w_001_VW38.rod
   VCID: 2F307821079321527AC-807A SFD [x]
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5H0 919 605 B    HW: 5H0 919 605 B
   Component: ABT_W_10       H49 2103
   Serial number: APUFP509122300010682
   Data carrier:
   Subsystem 2 - Part No SW: V03 959 820 GB    HW: -----------
   Component: EUR 2023/24    --- 9085
   Serial number: --------------------
2 Faults Found:
0021 - Functional Limitation due to Energy Management
          [Function restriction via shutoff stage Q2]
             Freeze Frame:
                    Fault Priority: 9
                    Fault Frequency: 1
                    Reset counter: 29
                    Mileage: 9498 km
                    Date: 2026.04.15
                    Time: 17:43:49
                    Voltage terminal 30: 11.4 V
12316 - Clock Syncronization Failure
          U138F 00 [00001000] - -
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 21
                    Reset counter: 27
                    Mileage: 5725 km
                    Date: 2025.06.13
                    Time: 15:42:53
Address 61: Battery Regul. (A6)       Labels: 5WA-915-107.clb
   Part No SW: 5WA 915 107 B    HW: 5WA 915 107 A
   Component: BMS_48V_LiIon H10 1501
   Serial number: 252300019022400 Dataset Number: V03935363TB 0001
   ASAM Dataset: EV_BMSmHevCATL 003012
   ROD: EV_BMSmHevCATL.rod
   VCID: 46DE3D858829801AA9A-8012
1 Fault Found:
32782 - Real (Clock) Time
          U3017 00 [00101000] - Implausible Signal
          [BMS_Systemtime_Error]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 32
                    Mileage: 7810 km
                    Date: 2000.00.00
                    Time: 00:00:00
Address 6C: Back-up Cam. (J772)       Labels:| 5WA-980-556.clb
   Part No SW: 5WA 980 556 D    HW: 5WA 980 556 B
   Component: RV eCompact   H31 0344
   Serial number: FCLK20281023010 Dataset Number: V03935359FC 0001
   Coding: 02030004E43000
   ASAM Dataset: EV_CamSysRVCCompaFicos 010024
   ROD: EV_CamSysRVCCompaFicos_010_VW38.rod
   VCID: 52F611D574612CBA352-8006
Address 75: Telematics (J949)       Labels:* None
   Part No SW: 5WA 035 284 J    HW: 5WA 035 284 C
   Component: OCU3HMQB37W   H14 0311
   Serial number: 0000000308VIJHC Dataset Number: V03935447ZH 0001
   Coding: 023800109068A8209405460071002607
   ASAM Dataset: EV_OCU3HMQB37W 002029
   ROD: EV_OCU3HMQB37W_002_VW38.rod
   VCID: 4DCC02A96D5F7342680-8018 SFD [x]
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 2Q0-980-653.clb
   Part No SW: 5WA 980 653 D    HW: 5WA 980 653
   Component: MQB MFK 3.0   H12 3405
   Serial number: EB7590902240040 Dataset Number: V03935412E  0001
   Coding: 0000088811484040409E00001020002000018000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005055
   ROD: EV_MFK3ValeoMQB_005_VW38.rod
   VCID: 50F21BDD7A6D5EAA036-8004
1 Fault Found:
1126464 - Databus
          U1123 00 [00001000] - Received Error Message
          [VMM_02_VZM_Warnruckeln_nicht_verfuegbar]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 27
                    Mileage: 9485 km
                    Date: 2026.03.05
                    Time: 08:52:54
Address C4: DC/DC Converter (A7)       Labels: 4K0-959-663.clb
   Part No SW: 5WA 959 663 A    HW: 5WA 959 663 A
   Component: DCDC_GEN_2 H24 0208
   Serial number: DC23495001939 Dataset Number: V03935347TK 0001
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_DCDC48VFLEXAU581 005013
   ROD: EV_DCDC48VFLEXAU581_005_VW38.rod
Address CC: Starter-Generator (C29)       Labels: None
   Part No SW: 05E 903 018 G    HW: 05E 903 018 G
   Component: iBSG4U_000    H16 0225
   Serial number: 5231220100143
   ASAM Dataset: EV_SGCM600210005E903018G 002004
   ROD: EV_SGCM600210005E903018G_A02_VW38.rod
   VCID: 261E9D052869601A89A-8072
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-572.clb
   Part No SW: 992 941 571 AH    HW: 992 941 571 A
   Component: LED1L         H25 9204
   ASAM Dataset: EV_LLPGen3LKEBODPO68X 002003
   ROD: EV_LLPGen3LKEBODPO68X_002_VW27.rod
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-572.clb
   Component: LED1R         H25 9204
   ASAM Dataset: EV_LLPGen3RKEBODPO68X 002003
   ROD: EV_LLPGen3RKEBODPO68X_002_VW27.rod
Address 8107: Antenna (J666)       Labels:* None
   Part No SW: 5WA 035 741 B    HW: 5WA 035 741 B
   Component: TrxModulHigh  H10 0083
   Serial number: 0000000310VIRG6 Dataset Number: V03935364CE 0001
   Coding: 02380011040080
   ASAM Dataset: EV_TrxMLGEMQB37W 005006
   ROD: EV_TrxMLGEMQB37W.rod
   VCID: 43D82491BB1BB5328E4-8016 SFD [x]
4 Faults Found:
0080 - Databus
          U1121 00 [00100000] - Missing Message
          [Ethernet-Datenbus - fehlende Botschaft- Systeminfo_01]
0081 - Databus
          [Ethernet-Datenbus - fehlende Botschaft- POS_GNSS_05_Position]
0083 - Ethernet Databus
          U1541 00 [00100000] - Missing Message from Information Electronics
          [Ethernet-Datenbus - fehlende Botschaft von der Informationselektronik]
0096 - Data Transfer Car2X
          U153F 00 [01100000] - Certificate Update Failed
End----(Elapsed Time: 01:29, VBatt start/end: 11.7V/11.7V. VIgn 11.9V)-----
------------------------------30 Faults Found------------------------------
